7m-gte dowel pin removal question
Enraged
A HG job took HOW long??
24
Victoria, BC, Canada
We welded old bolts onto mine and yanked them out with a slide hammer and a 3 jaw, didnt have a collet. Not the best (or advised) way to do it, but as long as you protect the block it can work.
bandit1730
75
Miami FL 33181
SUPRASTEVE;1936283 said:
Hey guys, its been a while. So, I have some time to work on the old supra motor. I got it all apart but, I can't figure out how to get the two "Dowel Pins" that are on the surface of the block off. I heard vise grips but, I didn't want to go that route. Is there any tool and if so can you someone point me the direction as to where I can acquire this tool or any methods to take the pins off without gouging the surface of the block. Machine shop is a negative.
Thanks,
-SS
Probably by now, those stubborn pins are out but I want to share how I pulled mine's off today. This is an easy step by step tutorial.
Step 1: Get a hold of grinder/cut-off wheel + a hammer + washer + pry bar & flat piece of metal (most of us have this tools handy).
Step 2: Place the washer over the pin.
Step 3: Convert your pin into a "nail head" by grooving opposite sides with cut-off wheel.
Step 4: Place a piece of metal under the pry bar in order to protect your block.
Step 5: Hit the pry bar against the pin with a hammer to further secure coupling.
Step 6: Pull that stubborn dowel pin out.
Step 7: Look at your pin free/undamaged block.
supraguy@aol
Well-Known Member
Dec 30, 2005
4,282
72
Atlanta
Hmm,
Your block's the same color as mine.
I used to use a big washer that went over the pin and a good pair of sidecutters, no damage to the block and pin free in minutes with a minimum of fuss.
Knocking them through you run the risk of splitting the block.
