7m-ftw build
hornet7288
260
Savannah, GA
I am actually down in milledgeville for school right now, but my home home is in Grayson...gwinnett co.
---------- Post added at 06:27 PM ---------- Previous post was at 06:24 PM ----------
Here is what all we got done today.
mhg on and ready to go
all torqued down
Where we left it at the end of the day
That's all for now. Hopefully more to come next week!
Linchmob87
128
Bowersville,GA
What is up dude...is that the hood I sold you? Anyways shoot me a pm on what your machine work costed you....got me a street stomper block I am fixin to tear into. I will give you my 2 cents on staying stock, YOU WILL WANT MORE! Trust me, boost is nice. But looks good man. Keep us posted.
-Chris
j3r3my
240
mass
if you plan on eventualy making power you'll regret using those pistons..i know i did and im now redoing mine with probe pistons from DM if i dont go 2jz,but your build is looking good!
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
hornet7288;1639079 said:
Does anyone know where the second plug goes as shown in this parts diagram?
http://www.cygnusx1.net/Supra/Library/EPC/291220/catalog.aspx?F=1105&P=2
It's the plug at the very top...11432C
I have one of the plugs in as seen in this picture
http://i167.photobucket.com/albums/..._616349748399_39807108_35507857_1551299_n.jpg
The diagram is showing two of the same plug, but I don't see anywhere the second one would go. Thanks!
One goes just to the upper left of the turbo drain and the other goes at the very front of the block just above where the number stamp is (to the right of the oil filter) Also make sure that one at the back is tightened down and the identical one at the very front was installed or you will have no oil pressure and oil all over the floor!
BTW the gold core plugs are brass whereas OEM plugs are steel. Steel can rust out over time which is why a lot of people use brass. Just make sure they didnt use Dorman brand core plugs on your block, i have heard horror stories of them popping out, you can do a search on these forums and see for yourself. Only takes one overheat to kill an engine.
dubsupra209
CENCAL SUPRAS
Mar 6, 2009
1,810
Merced, CA
hornet7288;1639325 said:
Are these the plugs listed in the parts diagram that I posted up?
yea looks like the same diagram i got my parts numbers from..i think there's 11 total or so don't quote me on that its been almost a year now since my build.
hornet7288
260
Savannah, GA
Went out and made some progress today. Got the egr cooler on, upper intake mani, exhaust mani, lower timing cover and crank pulley, upper front timing color, rail and injectors, knock sensors and ran the harness some.
Next time I plan on getting the turbo on. Just got the intake mani support bracket. I'll put that on, get the turbo on and then possibly the throttle body, water neck and some of these dang sensors.
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
Looks sweet keep it up! Super clean lookin. Did you use an OEM gasket for your EGR cooler? If you didn't i recommend that you do a search on that, aftermarket style EGR cooler gaskets tend to blow out and create headache- near impossible to change it with the head on and engine in
hornet7288
260
Savannah, GA
It was just the gasket that came with the set. Do you think I should look at replacing it? It's an OEM type set I suppose??
---------- Post added at 08:08 PM ---------- Previous post was at 08:07 PM ----------
Also....has anyone ever been intimidated by the wiring harness?? yeaaaaa......
