I've run both.
The upgraded CT hits boost hard and fast, but loses steam as you approach redline.  This was actually more difficult to drive - for instance, left hand turns, you need to stay off the pedal, or full boost will hit halfway around the corner and the back end goes nuts.  This turbo goes from zero boost to 18+ psi about as fast as you can snap your fingers.
The T4 based unit spools slower, and pulls hard right until you start bouncing off the rev limiter.  *Much* harder than the upgraded CT at high RPM, it's a very noticeable difference.  It's much more controllable - it 'rolls' into boost over several seconds, instead of punching you in the small of the back.  IMO, what you lose in instant response is more than made up by the extra response high in the RPM range, plus you gain a lot of driveability.
As for where in the RPM range these hit... I've never really noticed.  Once you hit this level of performance, when pushing the pedal on the right all the way to the floor, you damn well better be looking at the road ahead or you're going to kill yourself, and possibly a bunch of other unlucky people on or near the road.
