440cc injectors
c_vang
supraguy
Mar 25, 2007
21
Michigan
I was just wondering if I put a set of jdm 2jz 440cc injectors on my 1jz how much power and boost until I max out these 440's. Supported mods are S-AFC II, Aeromotive fuel pressure regulators, 255 pump, 3in intercooler and also piping, full 3in exhaust, HKS electronic boost controller, and a gt4067R? Any help would be great thanks.
honestabe
Happy as hell :D
Jan 15, 2006
3,713
Mount Vernon, WA, USA
With those injectors I'd run 350-400 RWHP (on a good tune). As for boost, that all depends on your tuner. You want to keep within safe limits of injector duty cycle (typically 80-90%). I'd get a wideband A/F so that you can monitor your A/F ratio as you drive, especially under boost. You want to be around 11.5:1 on your A/F while boosting to keep it safe and 14.7 while cruising.
honestabe;1252013 said:
Hey guys you should move your negotiation to PM's. Adam
This. Good luck either way, but take it to pms or the For Sale section. Thanks, Jay
877m
65
Lewiston, NY
you dont really want to run too much over 18 pounds of boost on 440s that what the 7mgtes have and you can run about 18 and anything over that u run the risk or leaning it out but if u have alot of supporting mods that ad power of increase airflow i would stay aroung 16
Blind Drifter
34
South Florida
Its best not to say "dont run over such and such psi" every turbo is different and will flow different CFMs. Horsepower wise is more accurate....
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
pmpdaddyt;1252997 said:
this is a newb question but up to what size injectors can u run before u need to change the fuel rail and fuel pump?
fuel pump wise, you should change it right away, it helps so you don't run lean in the high rpms. it would be pretty much like the 7mgte. for the injectors i was told anything more than 550s is recommended to be changed but i've seen people run 680s up to 880s on the stock fuel rail if it is modded so there is two places for fuel to enter.
rakkasan
Currahee!!
Fort Campbell, KY
Bull shit, try A/F ratio for accuracy. "Horsepower wise" doesn't mean shit
877m
65
Lewiston, NY
really? i j ust figured if your running 18psi its 18 psi but i guess that makes sence thas kinda why i say depending on your supporting mods thanks for the tip though
877m
65
Lewiston, NY
that sreally not a bad question because alot of people think just craming in injectors of a bigger turbo is going to make them wicked fast no you need to support every thing you do. a mean yea ok u can throw a big turbo on your car and big ingectors but if u dont have a fuel pump to keep up or a way to deliver enough fuel. you going to have a nice big turbo on a blown motor. but i personaly thing thats a good question
pmpdaddyt
No sup, just Soarer
Jul 14, 2008
9
Maryland
yeah, i realize that now. lol. i've been shopping around for a new fuel pump the last few days.
877m
65
Lewiston, NY
horsepowerfreaks.com has a walbero highflow for like 100 bucks with a install kit
