I'm gathering information and deciding for sure what direction I want to go in with my 2J swap that will most likely occur next spring/summer. I'll list my questions in order, so as to hopefully make the answers easier to understand for me and anyone else that stumbles on this thread with similar questions later
1. What has everyone decided on doing to make the ABS in the MKIII still function?
2. What driveshaft do you use with the setup?
3. Am I able to use my stock MK3 shifter with the setup, or do I need to do something custom?
4. What is everyone using for a speedometer input into the factory mechanical MK3 cluster?
I believe those are the questions I'd like to start with. I'm sure I'll have a lot of other stuff to figure out as my swap draws closer, I just need to decide 100% very soon if I want to go with the auto, or go to the added expensive of also doing the auto to manual conversion when I do the engine swap.
