2JZ-GE/T04/T4 header?
RacerXJ220
Interdimensional
Abalama
boostlogic makes a very good one.
Very reliable.
Ebay ones will work, you may have to modify/reinforce them to YOUR standard.
J
yankiwi;1151733 said:
I used an ebay/chinaman 2JZ-GE header on my NA-T swap. Quality was surprisingly good for the low cost.
I did need to turn the W/G flange 90 deg so the dump tube didn't face the chassis rail, but that is small stuff for you IJ.
Also needed to use a 3/8th spacer to mount the turbo, otherwise the comp outlet on my 67mm with a 90 deg elbow would not fit in the 7'o'clock position without hitting the chassis rail.
The material/bends etc in these manifolds is worth the cost alone!
Got any pics of it during the install and installed?
Very reliable.
J
Links please?
webbs7mgte
298
wisconsin
nice suprahero...tell me how that goes when you blow out your one drive gear lol....
but gl IJ we hope to hear i suggest getting a ebay one and modifing it... hope the ebst and let us know how it goes
yankiwi
221
DFW
IJ
Here's a few pics.
I remember now the main reason I used a spacer was that the outlet on my S cover would sit on the #1 runner. If I clocked the cover to clear the runner it faced into the strut tower, so to clock it down enough to clear the tower, and also give room for a silicon hose/clamp a 3/8ths spacer was needed. Obviously this issue would depend on which turbo you run.
The last small issue with my setup was limited space for the oil drain. I needed a 45deg fitting off the drain flange to clear the line away from the runners. Worked well but you can't drop a drain line straight down. The position of the drain then also limits how far down I could clock the cover....
Pics before any modification/spacer.
Pic of oil drain.
Best pic I have installed.
yankiwi
221
DFW
They are all over ebay, just search for 2JZGE mainfold. I got mine from Advan Racing. I paid around $250US for the mani/DP/Intake pipe, but the manifold is available separately too for around $100-150. I have seen a few of these from different vendors though and they are all the same.
Maybe a SM vendor has them?? May be a good first stop, as I don't know how most dodgy ebay sellers are with international shipping???
tsuper92
supra addict
Apr 7, 2005
1,376
mass
yankiwi are those just a universal set of plug wire's?i'm looking into this swap,got a 7m with a questionable build.
ian,you plan on using the 7m cps or you building some kind of fancy trigger wheel?
i was planning on using my aem and 7m harness.i've did some research on the cps and it doesn't require much modification.i'd also like to do a ffim with a different tb,which i'm sure you would be doing.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
the first mani,i bought from ebay for my 2jzgte was a nightmare for fitment.i wish i remembered who it was from,but it cost me $130 before shipping for a nick nack on the wall of the garage:(
hottscennessey
DONT BE A BITCH!
Jun 3, 2005
3,137
Richmond, VA
The ebay manifold has worked great for me. When I hyrdolocked my 2JZ, I took it off and inspected it all over for cracks, and I didn't find any.
While it was out, I decided to clock the WG flange so it wouldn't dump into the subframe any longer
It's a good manifold, as you can see I had no issues without a spacer.
I bought mine with a DP, intake pipe, and dump tube for 233 shipped in 12/06.
tsuper92
supra addict
Apr 7, 2005
1,376
mass
i just looked at the advan racing auction,this might be a good set up.it has a clocked t4 flange,were other's are straight.just thinking about cps clearance for the intake pipe.i had issue's on the first one i got for my 2jzgte car.
CPS clearence shouldn't be an issue at all with any of em :)
thanks for the input guys!
(keep it coming)
My plans aren't set in stone yet so I'll just play it by ear till I pull the motor and see what condition it's in.
