2j Build progress
cassio
Well Just wrapped up a fun-filled two days.
Currently have the engine on the stand to assemble the rest of the engine
before it is re-inserted into the engine bay.
The recipient:
The engine (* DO NOT BUY A VECCO Manifold!!!!)
had to drill out all of the stud holes, and grind down one stud.
Also had to chop off the wastegate tube :icon_evil
Custom pre 89 mounts:
A nice "dirty" test fit:
So far took everything back out and reassymbling the engine on the stand.
Pressurewashed and detailed bay.
Fabbing up custom lines for the hydro fan and misc other things.
Next:
Turbo installation (oil feed, return, exhaust, WG plumbing)
Redo IC pipes from my 7M FFI pipes
Redo Brake system
Install new rear subframe
Wiring :)
Should be done within the next 2 weeks (x my fingers)
-ian
Satan
Tampa
Damn Ian.... Looking great!! Here I am rushing to put the dirty/yucky 2J into the dirty/yucky engine bay, so that I can drive soon.... you even did some polishing!!
cassio
right now i have a t3 that im going to throw on (super t70, ebay turbo)
in a few months im going to upgrade to gt35, but the t70 will do fine for now.
Elvis i will be getting that tranny out to you within the next two weeks, lemme know if there is anything else you need and ill strap it to the pallete.
hardcharger
#1 935 groupie
Oct 28, 2005
186
San Diego
hey cassio man, I just figured I would tell you, that I have never heard of the gt35 goin on a 2j and being all that great, you might want to look at the gt40. On supraforums there was a whole huge post on it and they said that you just can't really boost enough on it and it puts the power in all the wrong places.
Satan
Tampa
Email me and lemme know what you want for the stock turbo assembly piping and turbos. I'd like to get it all polished up and push/pull in a weekend, instead of pulling off a piece at a time, to polish.
Christian says he may want the stock twins for one of his projects.
cassio
minor update,
Well as many people that do this swap change the fron x-member. I went with one-off custom brackets and decided to change my rear x-member (subframe)
My old 87 sub frame was cracked and i found a mint 89 frame to replace it with. Also decided to replace teh fuel filter again :)
gtfo!
re-installed thanks bryant! no idea we would damn near die.... finished later than we wanted to... on a school night too!
Dropping engine back in this friday to check some clearances, then saturday going for final mockup and install...
wiring to start Monday!!!
SupraMario
I think it was the google
The Farm
O.O thats freakin sweet.
And damn you have a nice shop.
Keep the pics and updates coming, I gotta see this thing finished now.
cassio
well took two steps forward and 3 back this weekend
t3 with t4>t3 adapter did not clear hood, so selling the turbo cheap to help fund a gt35
took out the butterfly fot the TRC
ground off trc bulbus mass and had some aluminum welded in the holes
finished a bit more, but the turbo was a kick in the nuts,
so now time to start fundning for the gt35
-ian
nissota
70
Jamaica
Elvis i will be getting that tranny out to you within the next two weeks, lemme know if8 there is anything else you need and ill strap it to th2e pallete.
A friend of mine just dynoed 428whp with a SS Auto Super t70 on a 2jzge + 1jz head + 1jz head gasket and with a mild tune at 18psi through a 1jzge automatic transmission.
Those turbos seem to be good value for the $250.00. He has had the turbo for a year with no smoking or problems.
