20 lbs on 60 trim pump gas alot?
S
Slow Poopra 7MGTE
Guest
do you guys think 20 lbs on a 60 trim to4e is alot for pump gas? just fishing for around for opnions
Turkish
188
Pump being 93? Here pump is 91 =/ If you are tuned it should be ok it is starting to push it though I believe? I could be wrong ;)
S
Slow Poopra 7MGTE
Guest
i was talking about 20 on a to4e t4 60 trim not upgraded ct 26 and 94 pump i should have been more specific but yeah i figured it would be a bit much for pump gas... so i'll stick to 15ish, thanks for the opnions and sorry for the cross post, i didnt mean to post in the technical section
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
psifactor said:
General rule of thumb is you shouldn't run more than 18-19psi on pump or your asking for detonation.
Well, if you have something to cool the intake charge, like an INTER-cooler meth injection or water injection, you can increase boost levels dramatically, on pump gas...
Just a thought...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
No no no, I think you misunderstand... I was talking about the NX intercooler kit...
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Yeah... Its pretty sweet...
The more heat you introduce into your motor, the higher the octane you need... To prevent detonation... The more boost you push, the hotter the intake charge will be...
However, if you can cool your intake charge, you can run higher boost... Alot of these methanol and water injection kits can be programmed to activate a certain boost level...
Jake
