Hi All
Currently I'm running 1JZ in my R32 with some modification on subframe. Means the Custom engine mount rubber from Volvo with stock 1jz engine mount bracket.
Last I bought 2jz Chaser & plan to swap with my existing 1jz. My concern is
1. Can I use back my existing 1JZ engine mount rubber & bracket to avoid any modification on subframe.
2. IF I'm using the 2JZ engine mount rubber & bracket,I have to re-modify the Subframe.
Hope I can get the advise & info. Thanks in advance
