Zeitronix Narrowband Simulation
teedoff00
14 psi boost
Dec 5, 2007
297
Selah, WA
I would like to try out my narrowband output feature of my Zeitronix and was wondering what to do with the stock O2. Can it be completely removed after the OX wire is cut and soldered to the Zeitronix narrowband output? I'm unsure if the heater element wire in the stock O2 will cause issues if disconnected.
Anyone done it or have any ideas? Can it be removed or does it have to be ran along with the Zeitronix wideband sensor even though the OX wire (stock O2 connection) is not outputting to the ECU, but the narrowband output from the Zeitronix in its place?
Thanks for the help!
teedoff00
14 psi boost
Dec 5, 2007
297
Selah, WA
Thanks GrimJack. Where can I find information on the correct resistor to install between the heating circuit? Thanks!
Trevor
