car still doesnt run, im gonna sum it up so hopefully i can get some more help. have a 89+ jdm motor in a 87. swapped sensors and what not, changed connectors on the harness, got the motor in the car. it will crank but wont fire. i checked for spark with no luck. checked resistance in coils (all three were .8 ohms, spec is .3-.5) with 12v. 12v also to ignitor, didnt do the 3v test. check resistance at cps, 170 spec is 140-180; also check at the ecu the confirm wires are ok. i redid timing, everything at tdc, cps installed according to tsrm and shaeff's pic
http://www.cygnusx1.net/Supra/Library/TSRM/MK3/manual.aspx?Section=IG&Page=24
http://www.supramania.com/forums/showthread.php?t=38775&highlight=timing
ive tried another coil pack and two different ignitors. my grounds have continuity to the battery. i bypassed fuel pump relay and tried to start it, just cranked. i then pulled the return line off the j-tube and gas came out, but it came out the gas tank side, not from the j-tube. im kinda confused about this.
if you read this far thank you for you interest, and if you have any idea or whatever, it would be greatly appreciated.
