XS Power - mk3 supra 8.2 @ 174mph Videos
I thought someone in the other thread said it was a 2jz...............I'm not testifying to it in court though.
DonS1mpson
Black Supramacist.
Mar 19, 2006
674
England!
I'd say it's a 2JZ. I've yet to see XS-Power stock anything for the 7M and I've only seen one or two 1JZ parts on their (UK) site.
Doesn't matter what's powering it, it is still one hell of a car.
Slow66
I think with my dipstick
Apr 3, 2005
1,457
Newington, CT
its a 2j.
Bondango
Supra Specialists Ireland
2jzgte
And believe it or not, it runs the XS-power GT45 turbo, currently the UK's fastest 6 speed manual Supra also runs the XS-power GT45 - Both cars are used by XS-power UK to promote there ebay and shop sales
The mk3 is owned by steve whittaker, i believe these to be the specs (Engine from his last mkiv supra)
TRD AFTERMARKET RACE PREPPED BLOCK 87 MM BORE 3100 CC TRD VALVE SPRINGS AND RETAINERS
HKS 2mm COMPOSITE HEAD GASKET
HKS 272 INLET AND EXHAUST CAMS
HKS VERNIER PULLEYS
HKS FUEL PRESSURE REGULATOR (NITROUS FEED) HKS R 40MM EXTERNAL WASTEGATES X2 HKS SQV
HKS TOPLOADER FUEL RAIL WITH 1000 cc INJECTORS HKS TEFLON CAM BELT HKS SUPER DRAGER EXHAUST HKS EVC 5 BOOST CONTROLLER
JE FORGED NITROUS PISTONS
TOTAL SEAL RINGS
CARILLO I BEAM RODS
TOGA RACE BEARINGS
POLISHED BALANCED TRD STEEL CRANK
MODIFIED SUMP
TOGA OIL PUMP & MODIFIED HOUSING
EARLS REMOTE OIL FILTER KIT
EARLS OIL COOLER
1MM OVERSIZE 3 ANGLE STAINLESS VALVES
LIGHTWEIGHT UNDERDRIVE PULLEYS
VEILSIDE PLENUM INLET WITH 100MM THROTTLE BODY
AEROMOTIVE A1000 FUEL PUMP AND FUEL PRESSURE REGULATOR
COLD FUSION DIRECT PORT NITROUS KIT
XS POWER GT45 TURBO MINES STRUT BRACE
CUSTOM INTERCOOLER FLOWRATED TO SUPPORT 1100 HP
Bondango
upgradedsupra said:
I am sure that A1000 is a typo..since the A1000 will not support that power it is putting out ;)
Duane
Duane i believe that was the Spec for his last mkiv, the engine was then used in the mk3 shell. So things like fuel delivery and drivetrain will be different (think it runs a powerglide). I deleted most of the irrelevent bits from that list, should deleted the pump too,
The Owner isnt a Internet savy forum person, so gettin spec on the car is quite difficult. Other sources say its not 3.4L but i cant confirm.
Dec 3, 2003
6,653
Canada
Aww I see...Yup sounds like an auto in the vid.
Duane
