Within 3 HC Points from passing air care. what to do..
jish17
12
Vancouver
i run the highest octane always go through at fully operational temperature attempting to get my cat as hot as needed. leads and plugs are fairly new.
GrimJack
Administrator
Dec 31, 1969
12,377
Richmond, BC, Canada
idriders.com
3 points is probably within the error margin of the machine... i get more variance than that running back to back tests here. Personally, I'd clean the wires, go back, and hope to get a reading on the good side this time.
8,900
jish17;1597392 said:
Allowable is 87, and I am at 90.
Is there anything small I can do to shave a few points?
Put up a copy of the emission trace.
87M-GTE;1597553 said:
run higher octante fuel too,
Baloney.
Even without the trace posted, do you have the original downpipe and cat in place, or did you replace the downpipe with an aftermarket unit that is a straight pipe? That can easily cause a rise, op temps or not.
Oct 11, 2005
3,822
27
Thousand Oaks, CA
My HCs nearly doubled without the precat. As is is, they have been getting slowly worse over the last 10 years. The culprit is most likely a tired 20 year old cat since fuel control is good.
Post up your numbers and we can compute your A/F, but I would be very surprised if fuel control is an issue here.
89supra7mgte
797
colorado
I have never dealt with emissions so this is in no way a suggestion. Couldnt you advance your timing a bit, just for the test purpose? Or would that create other problems? I mean over advanced timing runs hotter correct?
8,900
Then NOx goes up.
89supra7mgte
797
colorado
Not sure if it varies state to state but maybe by doing that he can lower the hc and still be in range with the increased nox? Also, i have heard of people creating vac leaks to pass, not sure how that would help but guess it depends on where you are at on the scales. Also heard of a pre cat exhaust leak? But then again i have no experience with emission tricks and such. So everything is hear say. but determining fact from fiction is always good.
8,900
Wow. I have to reword all of this. I guess that is what happens late at night.
It may be as simple as new spark plugs. But since we still don't have the emission trace posted yet, this is all conjecture. Creating a vacuum leak will cause a lean condition which will drop carbon monoxide, but that will also cause a lean condition and give the ECU a hard time to correct the condition with feedback.
mkiiichip
1,434
WI
We need the rest of the readings.
Is the vehicle run on a dyno during the test or simply reved to a higher RPM?
Is timing checked durring the test?
Did the technician have the car at operating temp before the test? (common mistake that "go fast" techs make, bringing me allot of work over the years)
I am not familiar with "air care" standards, but california smog, I know well.
Just a good, hot cat, while in fuel control, and a good ignition system, will pass HC. (as long as CO is in check, pre cat)
8,900
I had to rewrite what I wrote. Causing a lean condition doesn't cause a rich condition. I guess it was late when I said that nonsense.
