Okay, so this is my first post on the forum, I've been searching for a few days on the issues I've been having. To start off, I bought this car from a guy in the army who didn't have time to finish the swap from the original 7mge to a 7mgte. Supposedly the engine has only about 90k miles on it, but it looks to be roughly treated. Many hoses and wires have been hacked. The car is an 86.5 with a 5-speed. Pretty sure it's the w58 from the searching. The ecu is not the correct for the car. It has the grey plugs and the harness seems very rough. The harness has many missing plugs and the engine bay is littered with a mix of yellow and grey plugged parts (ignitors etc) The cold start injector plug on the thermostat housing does not fit so that proves it is the later wiring harness on an older engine, correct? The a/c fan sensor and a/c fan switch wires were cut off of the thermostat housing as well. Many grounds are just hanging down, and the speed sensor off of the w58 was cut. My question and reason for posting is that I've been searching and I'm new to the forum and the car and just looking for some guidance. Should I get a brand new harness from tweak'd and ecu off of a member/ebay and end all the wiring headache? Or is what I have here salvageable from what you guys can see? Thanks for your guy's help, and sorry for the ignorance and jumbled post.
Here are some pictures I've taken in the tear down:
This was also plugged in one connector by the ecu..
The ecu that came in the car when I bought it
Pass. side engine bay w/ yellow plug resistor, loose hoses and plugs
Driver side engine bay with yellow resistor again but with grey plug. Also ignitor confusion, had a coil&ignitor from a 5m bolted in place but not attached to anything so put this one in that was in the trunk with other misc. engine parts
And lastly, the entire engine bay as it stood.
Like I said above, any help would be appreciated, I'm in this build alone so far because I havent been into the supra scene for long enough to make friends that know anything :1zhelp: I have found the tweakd harness and possibly a craigslist parts car with the harness (much sketchier, dont know if the harness is rotted) I searched, but I honestly haven't found a harness or car in as bad of shape. Thanks for looking :icon_bigg
