wiring harnest differences
Status
Not open for further replies.
againstdawall06
298
mo
i just put in a JDM 7m-gte into my 87 turbo supra. looks like it was a 89-92 automatic engine, the wiring harnest is perfect. so i used that wiring harness, problem is the wiring harness is to short to make its way to the ECU. any alternatives other then extending the wiring harnest? also i searched and read one post saying that i need to use my 87 wiring harness due to some different sensors. is this correct? also i have a pretty good amount of connectors left over. im really trying to aviod swapping the wiring harness out. any help is greatly apreciated.
drjonez
the motor city
www.4cefed.com
that's HARNESS.
anyway, reuse your '87 harness. you'll save a ton of headache trying to lengthen and repin the later harness. you'll probably have to swap a few sensors as well as the plugs are different.
againstdawall06
298
mo
damn, thats not really what im wanting to hear. thanks though. is it hard to switch them out with everything on still? or do i have to take of the intake manni
Status
