Wire harness help needed, name that wire.
RIPDOTCOM
157
Tallahassee, FL
Dont know where these 2 wires go but as you can see the more than likely connect somewhere on the passenger side of the engine.
the next 2 gome out of the firewall under the afm .
Then theres this plug which looks like a cold start injector plug on my NA but cant find the cold start injector on the 7mgte
suprra_girl
7M POWAH! ;)
Auckland, New Zealand
www.supra.co.nz
i can't remember the colour wires you have in the first two
maybe the one coming out of the guard is the abs sensor plug? do you have abs?
last one is cold start injector, under way under the throttle body and you'll see it, if you look from the outside into the manifold look in the middle of the manifold sorta underneath and you'll spot it
Satan
Tampa
Cold start injector is a PITA to get to... I was able to re-connect mine, using a flathead screwdriver and one of those long "bent-nose" needle nose pliers.
The previous times I've had to disconnect or get to it, it was just easier to remove the throttle body. It's basically between a couple of the runners on the plenum, almost behind/below the TB. I started to try and remove the cold start injector to reconnect it, but it was easier to remove/replace the TB... Good luck.
Oct 11, 2005
3,821
25
Thousand Oaks, CA
For the CSI, remove the two nuts that hold it to the plenum, and pull it down a few inches. Then you have a little bit of room to get the plug on. Its a real PITA. Make sure you have a new gasket if you are going to do this.
