MDCmotorsports said:If you have the tools and the head isnt' warped...
You can have a BHG job done in a day to three days.
I assume take it to a machine shop to check if the head is warped? and if it is, deck it? For a OEM type composite gasket and non ARP headbolts should the block be worked on (from what i read, no). i just wanna figure out all the steps I need to do now on this before I do any of it. do i disassemble the head myself (pain to do) or have the shop do it? i am in serious need for reccommendations on what to do to get this headgasket done close to stock like other than the torquing of the head bolts.
What should I do about the fact the head is full of buildup (such as exhaust and carbon buildup. (exhaust has white gunk burned onto them), and a nasty amount is built up in the intake and exhaust ports (easier to clean).
