Will the 2JZGTE 550's fit into the 7M Fuel rail?
1988SupraDreams
509
San Jose, CA
I have a 2JZ laying around and wanted to put the 2JZ injectors into my 7M fuel rail along with the Lex AFM and Walbro 255LPH. My question is, will the injectors work with the 7MGTE fuel rail? My thinking is that they would. I couldn't see why they wouldn't, but I'd like to make sure before I go removing my fuel rail. Thanks in advance for the replies.
1988SupraDreams
509
San Jose, CA
Curses. Is there another vehicle of any make/model that has 550cc top feed injectors that would work for the 7M? I work at a parts store and get everything at cost, so I would be saving a boat load on injectors vs RC engineering.
MarkIII4Me
Project OVERKILL!!!
Apr 10, 2005
1,249
Charleston, SC
I'm currrently running Nippon Denso's out of an 87 RX7 Turbo. Make sure you get the low impedence ones. Pretty sure the later models use high impedence injectors which are incompatible with our engines.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
I have been looking for some of these at a decent price for sometime....they seem to be pretty hard to come by.
Good luck!
1988SupraDreams
509
San Jose, CA
Napa Auto Parts can get me six new nippon-denso injectors out of the closest Dist Center for 50 bucks each. Vehicle: 1987 Mazda RX-7 Turbo. I love getting parts at cost. Thanks again for all of your helpful info.
rumptis
나는 제프가 당신을 사랑
Aug 16, 2005
814
North Vernon, IN
Can you hook me up with a set of 6?
Facime
Leather work expert
Jun 1, 2006
2,716
Corvallis OR
high impedence injectors (which) are incompatible with our engines.
not entirely true, they only require a little rewiring. I know of several people who have used them.
noah89t
get naked & boost a supra
i used the high impedance 195500-2020 injectors for years. i had to rewire the resistor pack. they use stock 7m clips with some filing of the injector.
the tan 195500-1370 are low impedance, but you need new clips
they come from the fc turbo 2. but since that car uses 4 injectors, you will have to find 2 cars. the fd or last gen. uses 2 primaries and 2 secondary injectors iirc.
http://www.robietherobot.com/Storm/fuelinjectorguide.htm
the n/a used smaller injectors on the fc. all fd's were twinturbo
you can't change the flow rates of injectors. they can only be cleaned and tested. you want injectors with flow rates within 2% or less of each other.
the problem with finding used ones is that the spray patterns could be different b/c of their age and you are replacing your 19+ year old injectors with 17+ year old injectors. i had 8 total and sent them off to be checked when i first got them 5 years ago. about a month ago, i sent them off again to be checked and found that 2 were leaking internally, 5 were within 3% of one another and 1 was flowing 14% higher than the others. needless to say, i had the guy throw them away for me and now i have to start over and buy some proper 550's.
noah89t
just found this again. it is pretty useful.
84-85 | 13B NT | low | square | center | 680cc | orange | 195500-0900
86-87 | 13B NT | low | square | center | 460cc | red | 195500-1350
86-87 | 13B T | low | square | center | 550cc | tan | 195500-1370
88 | 13B NT | high | square | offset | 460cc | purple | 195500-1350
88 | 13b T | high | square | offset | 550cc | purple | 195500-1370
89-91 | 13B NT | high | oval | center | 460cc | red | 195500-2010
89-91 | 13B T | high | oval | center | 550cc | purple | 195500-2020
