I was wondering if I will get a headache from the following fact:
Since my current turbo had a bit too much shaftplay I figured I would order an upgrade 57-trim from Driftmotion along with all the other stuff I needed.
However I have not yet gone as far as getting a set of 550s and a lexus AFM, figuring this would come later on.
I will be installing a Walbro-pump as well as the Aeromotive AFPR-kit from driftmotion.
Now, I have not built a 3" exhaust yet, but that is in the making this summer, and my question/s is basically:
Will I run into fuelcuts on a stock exhaust and a 57-trim?
Will I run into fuelcuts on a 3" turbo-back exhaust and a 57-trim?
If not, then what pressure can the stock injectors/afm be used to?
The reason I am asking is that i _assume_ that an upgraded turbo will flow more at the same PSI/BAR and thus hit fuelcut at a lower pressure, correct?
P.S. It is all ordered through a workshop that a friend and fellow supraowner runs, so I wont be installing it all on my own
Thanks in advance.
Thanks in advance.
