Backlash2032;1623802 said:Wow. Same thing. Except when i shift reaaaaaaly smoothly, then it doesnt clunk.
Poodles;1623198 said:Did you check the spherical joints in the hubs?
Poodles;1630064 said:I'ts not the LSD...
Toyota (as well as most other OEM's) use a crush sleeve to se the preload on the pinion bearings. Crush sleeves suck, and wear out losing preload on the bearing and allowing the pinion to move around. The only thing at that point keeping the pinion nut on is the staked in part. Put enough force through it (oh, like 4 wheel drive low on 4.11 gears and 31" tires) and it shears the teeth off.
speedmaster;1630082 said:Thanks for the insight poodles. Is it costly to overhaul my existing differential and replace this crush sleeve? or do you think I should just swap out the lsd (the whole case) with a cheap lower milage one?
forum.ih8mud.com
