Will it make 700?
Will it make 650-700 rwhp
  • I think so
    Votes: 19 47.5%
  • It'll be lucky to make 300whp
    Votes: 0 0.0%
  • It'll make more than duane AND KWnate
    Votes: 2 5.0%
  • It's going to blow up
    Votes: 19 47.5%
  • Total voters
  • Poll closed .
gixxer750
2jzget comingsoon!
Mississippi
Will it make 700RWHP?
I know about what its going to do, and 700 is expecting too much. ha
Mods are Turbonetics T66, built shortblock, p&p head, stock cams, valve clearances set close to min. spec, Short runner FFIM, tubular header, custom 3.5 full exhaust, 720 densos, AEM EMS, 12X24X4" intercooler, Speed density, 3" intercooler pipes, 2mm HKS gasket, 40mm HKS wastegate, Q45 TB and ...... 30 psi on 114 leaded
6o4turbo
It never ends...
Oct 27, 2005
215
B.C. Canada
If you don't make mid 600's on that setup at 30 PSI, (Assuming the motor is strong, and you have a good tune) then something is wrong.
Good luck, if you don't make 700, might as well blow it up trying!
gixxer750
2jzget comingsoon!
Mississippi
I am not scared to blow it up..... hahaha. I will rebuild it better next time.
The motor has less than 10k miles on the forged setup, and has made 550 RWHP since it had about 400 miles on it....lol
tissimo
Stock is boring :(
Melbourne, FL
not if you use the same dyno ;)... but it probably wont make 700 anyways... you'll probably need more boost for 700whp..
Tun_x
Built to do the NASTY!!
Utah
vp import and jack the timing up 1 or 2 degrees and you will have it .
Jason
Apr 6, 2005
339
Alpharetta, GA
The 720cc inj gonna limit you to ~650whp. Beyond this and you'll begin cycling the inj above 80% duty cycle, unless you increase static / base FP - which then violates logic of having a reasonable safety factor.
Furthermore, as Slow' indicates, the turbo is the more significant limiting factor to achieving 700whp (turbo only) - 30psi and within it's efficiecy zone.
But eh, give it a shot, and report back. It'll be an education for all of us:bigthumb:
