Hopfully you didn't run it out of oil:3d_frown: Check on the header side over the block, below the distrubutor, there is a single wire that goes to a round sending unit, it slides off towards the wire. Check to see if it is making good contact, its the oil sending unit. If the oil hasn't been changed for a good while the oil filter could also be plugged up.7MSupraGE87na said:Well thank you guys, my bird has been given water and the light shut off. but now my oil pressure is back down at 0 after raising a bit. I'm going to give it an oil change or spend like $30 and have it done by a shop (cuz im lazy) and then hope it works. I just hope nothing was damaged
