Wich differential is better for 1/8 track 3.9 or 4:30?
CarlosPTR210
435
Calexico,CA
www.ptr.com.mx
Wich differential is better for 1/8 track?
Stock 3:90 Turbo ’88 differential or 4:30 NA Differential
My car Set Up (DD car)
7MGTE
NOS 50HP’s Shoot
Garret 35R Turbo, High Boost 18 Psi, low boost 11 psi
Act Stage 3 Clutch Kit
Fyndanza Flywheel
18” wheels
Back tires Drag Radials
deabionni
The Lurker
Sep 16, 2007
431
Kalkaska, MI
^^^ Agreed. 4.30.
In short, the higher the number is, the faster the car will accelerate. The downsides are, you turn higher RPM's at highway speeds, and your top speed will also be lower.
RazoE
Boobs/Boost, my favorite
Jun 13, 2006
4,946
Los Angeles
www.cafepress.com
better start shifting quicker, too..:D
the RPM's on the highway are a little too high for me with my 4.30, I'm doing 80 and I'm at 3K rpms...
might swap to a 3.9 later...
gofastgeorge
944
Texas
If you find a set of 4.56 gears would be better yet.
The guy that goes by the ID mx83*gx81 sells a lot of JDM Supra/Cressida parts on eBay has different gear sets listed from time to time.
You might want to ask him.
Oh yeah, better get some really sticky tires :)
figgie
Twin Cities, Minnesot-ah
W58 transmission because on the R154 + 4.3 back end. 80 will net you around 3600 rpm.
The r154 + 3.9 rear = 70mph @ 2900 rpm (going from memory).
