So I understand that even if you do not have a BHG your block is most likely warp still.
Ok so you have to check the head and block surface for straightness to see if its warped and all, but if you did not have a BHG you have to check it still rather you have it or not when you pull the head. The maximum warpage is .05mm/.0020inch.... So if your head it warped at the time your pulling off your head under BHG or not, why would it be worth it to resurface the head for a MLS headgasket that requires that straightness if its just going to warp again eventually? Wouldn't that mean the HKS and Cometic MLS be pointless?
I pulled my head finally and cleaned the block of the old gasket stuff. I checked the block surface with .003 inch and it did fine but now have to go back and check it at .002 inch by what the TSRM ask for (the .003 inch was what the haynes book said.. weird). It just bothers me why waste the money to resurface it if its just going to be off again.
