Who here makes solid motor mounts?
fstoy
Soon to be Evil Twin
Texas
I am looking for a custom set of either steel or aluminum 89+ mounts.
I would like the mounts to me 1/2" shorter than stock.
My turbo header combo sits higher than normal and i am having hood clearance issuses. Dropping the engine 1/2" should take care of my problem.
I cant see why having the engine dropped 1/2" whould create any problems.
So if any one can make me a set shorter than stock, hit me up.
Dave
supra_ed
415
ohio
bic performance in vendors section makes solid mounts- dont know about 1/2 in shorter. will the pan clear the cross member??
fstoy
Texas
Thanks. I PMed him.
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
welding stock mounts is real easy but it wont make them 1/2 inch shorter. Problem with making them 1/2 inch shorter is it will change the alignment of the bolts. it would most likely require mockup to insure accuracy, either that or very accurate math.
Edit: pics of my stockers welded.
becauseican
Vancouver
www.bicperformance.com
Yes I make them, and there is a group buy going on right now !!!
Now about the shorter ones, I also wonder about oilpan clearence. I know the 1jz motorr only have about 1/4" before the pan will touch the crossmemer. You could always buy the regular length ones and cut them down the exact amount that you need, you just need a hack saw.
Randy@ BIC performance
TurboStreetCar
Formerly Nosechunks
Feb 25, 2006
2,779
13
Long Island, Ny
it would change the bolt patern on the mount wouldnt it? it would be like milling the surface of the intake ports on a cylinder head for a V8, the ports would be lower and moved further apart.
maybe the amount needed to lower the motor is not enough to effect it that much?
