Who here has done 89+ tails conversion on a pre 89??
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
Since we are on the 89+ conversion topic. When I put my JDM ones in the tail light warning light comes on. I know my sensor is sill working beacue I tested it. I heard something about using a resistor. Anyone know anymore about this?
FredMk3
mk3 for life!
Sept-Iles/Quebec
BorHor said:
Since we are on the 89+ conversion topic. When I put my JDM ones in the tail light warning light comes on. I know my sensor is sill working because I tested it. I heard something about using a resistor. Anyone know anymore about this?
I did the swap and my lights works good, and warning light doesn't come on. One thing I did is got 89+ USDM bulbs holders for my JDM tails so I can keep my rear side markers working.
My only problem, new from tonight, is I got a major bad ground since when I aply the brake or use the turn signals my voltage drop badly, turning off my radio sometimes, my Defi controler and gauge and my headlights dims pretty much. :icon_conf, problem is in the bulb holders since when I disconnected them it doesn't do it.
You said you tested your failure box...maybe you could still try this: http://www.supracentral.com/content.php?article.111
