Who has anti-surge housing?
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
I am looking at this because I have to decide if i want one.
Precision makes one for my turbo - the common type housing with many holes drilled in it.
Has anyone used this type before? I know HKS has one or 2 that come this way.
According to Precision, if I run this turbo / housing combination, I can run no BOV at all without concerns, but I still need to talk to the main guy there cause he was not there when I called.
empera
Authorized Vendor
Philly.
i do but i havent had the chance to really put the turbo to its test, on my old manifold setup there were no problems but i used a greddy type s.
Orion ZyGarian
Jeff Lange wannabe
Apr 2, 2005
1,490
Sarasota, FLorida
www.suprastore.com
HAH! Who said that?! I'm assuming you're running over 10psi...even if you werent, some sort of bypass valve is extremely important for turbo longevity.
Anyways, I know how to tell on a compressor map when you'd need one...but otherwise...I'm curious as to how to see if you need one.
sneakypete
Regular Member
Jul 18, 2007
1,129
Central NJ
on my turbo, it comes with the anti surge house, but i chose to leave it alone.... undrilled. until im ready to push that power, im gonna leave it as is, and keep my bov. once my new motor is done, i might reconsider.
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
Why are you so concerned with not running a BOV? Just get a good one(or 2 for big boost) and run it/them. If its set up properly it will not leak, and will help keep the turbo spooled and happy.
