which wire for the reverse lights on the ECU
supra4runner
23
vancouver,bc,canada
ok i need to find the wire on the ECU that is for the reverse light. im struggling here, need to get them working for my vehicle inspection that i got issued awhile back. anyways..the 7m isn't in the supra, its in an 874runner. i have found the one from the truck back cant find the one on the supra harness ! any help would be great. i've been reading the haynes manual and the TSRM manual. i hate reading wiring diagrams...some one plz help !!
garagefujimoto
Local Tire Destroyer
May 27, 2005
997
Calgary, Alberta, Canada
I'm bored and getting paid to look this up for you LOL, plus you are also from Canada and had the ambition to put a 7M in a 4runner
In a 1990 Toyota Supra, the manual transmission R154 has a reverse switch on the side of the transmission case.
The red with black wire leads to the taillamp harness and connects to the 2 back-up lamp bulbs.
The yellow wire comes from Junction Block #3 Pin B14, and is supplied by the fuse box, and the relays etc etc.
Should be a simple and and out as long as:
Power gets to the switch
Switch opens in R gear
Power makes it from switch to bulb holder
Bulb holder makes contact with non-burnt bulb
Bulb is properly grounded
supra4runner
23
vancouver,bc,canada
hmm..it seems the that on the truck its the same as the car. there are 2 wires on the side on the tranny. i have found those, and yes one is for the 4wd (transfer case), the other one as i mentioned is on the side for the reverse. but there are 2 wires, assuming both go back to the driver/passenger side back up lights.
so say if i splice into the 2 wires going into the side of the tranny and splice into the junction box ## b14 it should work right ??
and which one is the junction box #3 ? is it the huge connector,meduim connector or the smallest one.
thanks for looking it up man, atleast your getting paid for it.
garagefujimoto
May 27, 2005
997
If I understand what you are saying right this sentence might simplify things.
"Put power from somewhere, even if a temporary jumper wire, on the yellow wire of the reverse switch, put the transmission in reverse, and the power from the yellow wire will then go into the red/black wire"
As long as your power source works whenever you hook it up (key-on/fuse works etc) and the switch works and the switch red is connected to the bulbs and they are grounded, you shall be ok.
