Which wideband kit do you guys suggest using?
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
i'm looking into getting a complete wideband kit but i didn't know what would be a good wideband kit to use? i was looking at some like AEM, NGK, or PLX.
tissimo
Stock is boring :(
Melbourne, FL
Innovative or NGK.. something that can recalibrate.. Over time the sensor will change and if you cant recalibrate it will become inaccurate..
86_sports_1jz
slow 700hp build...
Aug 27, 2006
1,217
OK
so the ngk can be recalibrated? will it recalibrate itself or do i have to do it? if so then i'll just get the kit since Innovative does not offer a complete kit w/ a display.
bigaaron
4,692
Pomona, CA
www.driftmotion.com
The Innovate LM-1 can directly interface with the Stinger. It can be calibrated too, which is a very good feature. It has two outputs you can configure to run a gauge or to go to a stock ecu to replace the stock narrowband sensor.
I really like the Zeitronix zt-2 software for data logging, if you are not using a standalone, I highly recommend it. It can also replace the stock o2 sensor with it's simulated narrowband output.
Tim
regular member
Oct 16, 2006
272
CA
I just got the zeitronix ZT2 and it is awesome. I will be putting it in this weekend. It has some nice features (digital egt, digitsl boost,ect...)
Tim
regular member
Oct 16, 2006
272
CA
I mean as far as the display and the features go, its awesome. I am sure that once I install it I will be very pleased with it.
Zazzn
l33t M0derat0r (On some other forum) n00blet here
7
Toronto/SF Bay area
zt2 has by far the best logging software, I love the zt2 so easy to use so easy to follow.
I don't like the screen too much though becasue it's not fast enough to update.
Other then that the unit rocks. can log so many things, and hook up absolutelly erverything you need to tune it.
Use a APexi turbo timer and use the 1V out of the zt 2 to the apexi and you'll get your WB off the 1V not as accurate but you can see whats going on, then hook up a laptop to actually tune / record and take 10 min to see how EGT, BOOST, AF, RPM ect... it has better read outs then the emanage, and i like it even more then the aem readouts.
