Which shifter is this?
empera
Authorized Vendor
Philly.
so i got this off an n/a, seems to be a short throw, says S3 on the side, i think i've heard of this before. I just want to make sure i can use this on my turbo's tranny. i cant remember if they are interchangeable...the bottom of the shifter is longer then the stocker tho so i dunno. If you have any info on this please let me know...
thanks.
-emp.
KeithH
Portland, OR
I've got the S3 and I LOVE it! BTW: the S3 is currently on sale over at SS. This is a GREAT time to get one.
Shifts are short and crisp - just a quick flick of the wrist and you are in the next gear.
empera
Authorized Vendor
Philly.
it doesnt quite look like it...mine has a rubber part to it, the one SS has a metal part...
empera
Authorized Vendor
Philly.
:1zhelp:
So i tried installing this shifter today...when i bolted it down it was stuck and didnt want to shift/move. it moved when it was loose though!? so my question is am i missing something? if so i probably left the other part in the junked car :( so what should i do!?
pics..
Please help!!
thanks,
-emp.
Mr. Sinister
192
Chicago
Try pulling up on the shifter and then try to shift. If it shifts, then the shifter is sliding down too far and catching on the lower set of pivot pins. I'm not sure how this shifter was designed, but the C's shifter come with two half-circle inserts that create a raised floor for the shifter to rest on. You pull out the black bushing at the bottom, drop the half-circle inserts in, put the black bushing on top of those, then put the shifter on top of them all.
empera
Authorized Vendor
Philly.
ok so i have 1 spacer/insert i need the other and i tried c's short shifter to see if i can order one, they said no.
here's wat i need.
:1zhelp:
Supra469
495
Maryland
How does this compare to the C's ?? Thanks.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
NM short throw shifter's are far cheeper and are shorter throw then c's or other that i have tried i even have video of befor and after
KeithH
Portland, OR
The C's and the S3 (or whatever the official name is) are both works of art and are well worth the $.
If the S3 is still on sale over @ SupraSport it isn't much more than then nm shifter and you don't have to ship your shifter out in order to get one.
