where to drill?
Boostin4Life
Boost addict
Jan 7, 2006
47
Oklahoma
Installed my OBX boost guage, well I ran the wiring but I do not know where i should drill the hole for the vac hose to run through to go to the engine bay? any suggestions?
shaeff
Kurt is FTMFW x2!!!!
11
Around
dont drill any holes at all! :) i ran mine through an existing grommet that had four wires running through it... works great.
-shaeff
Stanzaspeed
2.5 Twin Turbo R
Calgary, AB
try and find a hole that has been pre drilled either from factory, or maby for an aftermarker allarm. thats how i ran mine, just pulled the other wires out of the way enough to run the vac line through. :icon_bigg
BoostFreak
74
Ohio
right by the clutch pedel is a empty hole, if you look in the engen bay to the lower left of the clutch master cylender their is a pyle of sylacone, and a small hole in the midl of it, that goes all the way into the cab right by the clutch pedle
