Where does this plug go from the Engine Harness?!
jdemara
285
North Delta
I just did a HG repair. Connected everything and there is ONE plug (on the exhaust side of the harness) that I have no idea where it goes. There is oil pressure sender, cold start injector switch, coolant temp, MAF, etc all on the side right near the pwr steering resevoir.
Heres a pic .
Anybody knows what this plugs into and it would be a HUGE help!
Kinda hard to tell, but that looks like the CSI time switch connector to me...could be for the ECU temp sensor. The connectors look a lot alike.
The CSI time switch is on top. The ECU temp sensor is on the side...you can see it in the pic and it looks like it has a green connector already on it.
92TealSupra
Supramania's Parts Man
Sep 2, 2008
1,585
Great Lakes State
Alright thank god!! * You all have no clue how excited I am, we have a post like this one! I had the same connector on my '91 Automatic Supra Turbo. It was like that when i got it, and the car was stock. It did not plug into " Anything " and if it did I could not find out where it goes into.. it kind off comes off where the oil pressure wire is and has the heat protected wrap around it, almost as if it goes somewhere around the exhaust manifold, again.. I would not locate any missing parts or where it could possibly go.
jdemara
285
North Delta
yep! no idea! eeeeeverything else is plugged in and im 100% positive cuz i remember them all perfectly.
owell! guess ill just leave it ! haha
