where does this go??
Kevin
7mgte -> 7mgte swap done.
Apr 20, 2009
865
Windsor Ontario Canada
where does this wire go (its yellow with a black stripe and has a rubber cap thing on the end.. )
just a quick correct answer.. no need to discuss anything thanks
san supra
833
san antonio
oil pressure sensor and its on the block next to the oil line for the turbo(not the oil return line). its domed shaped and that connector clips on top of it.
probably have to take off that intake hose
radiod
1,342
Abbotsford, BC
Shouldn't have to if you do it from underneath. I had to rewire mine and I was able to get at it from underneath.
