Where does the M1 ground get grounded?
Freshmaker
396
Oconomowoc, Wi
My dash is doing some wired things. Voltage gauge only showing 12v for instance.(alt is putting out 14.7volts) I checked the resistance between the M1 ground and the chassis and I am getting 10 ohms. I want to see if the wire is bad or the connection. I think there is a diagram of all the grounds somewhere? I couldn't find it.
Where can I check that M1 ground connection?
Freshmaker
396
Oconomowoc, Wi
10 ohms seems like a lot for a wire going to the chassis ground.
Does that wire go straight to the battery or does it get grounded somewhere else?
Justin
Speakers?
Spokane, Wa
It is alot.
I don't' know, but I bet you'd be able to find out in the TSRM, IIRC there is a few pages that deal strictly with ground point locations.
Mk3runner
2,033
Nor Cal
is that the one where a couple of grounds are bolted too? I think thats the same one your talking about.
