My dash is doing some wired things. Voltage gauge only showing 12v for instance.(alt is putting out 14.7volts) I checked the resistance between the M1 ground and the chassis and I am getting 10 ohms. I want to see if the wire is bad or the connection. I think there is a diagram of all the grounds somewhere? I couldn't find it.
Where can I check that M1 ground connection?
