where can I get this seal,
MA70Snowman
374
San Diego
I need the "Oil pump drive shaft oil seal" as named in the TSRM. (the seal behind the oil pump pully in the timing case. Its leaking and I called damned near Autoparts store i could find in the yellow pages, Toyota wouldn't give me a part number on it, and would only sell the seal w/ the WHOLE pump kit (282$) and NAPA doesn't carry it. so where can i find JUST this seal. Or just shell out the money and buy and engine gasket kit and have extras for later.
C
cnewingham
Guest
You can get it from Toyota. I have bought just the seal one time before. If noting else I can get you a full gasket set but that is over $100
MA70Snowman
374
San Diego
where from toyota would you recommend around here, i called our local dealership as stated and all they would offer to sell me is the actual oil pump itself w/ seals. I'll try again, (I did have the wife call, so who knows)
Oct 11, 2005
3,819
20
Thousand Oaks, CA
By the way, that seal is used on a jillion Toyota engines, I cannot believe NAPA does not carry it.
tem Number MSRP Core Price Price
9008031022 $8.92 $0.00 $6.78
Engine - Crankshaft & bearings - Crankshaft & bearings - Front crank seal
Front crank seal, camry - 4 cyl, 1.6l, 1.8l and 2.0l dohc 1991
Add to Cart Contact Us
Front crank seal, camry - 4 cylinder, 2.2l dohc 1992 - 1994
Front crank seal, celica, w/o turbo - 2.0l, 2.2l 1991-93 1986 - 1993
Front crank seal, celica, w/turbo - 2.0l, 2.2l 1991-93 1989
Front crank seal, celica, w/turbo - 2.0l, 2.2l 1991-93 1993
Engine - Camshaft & timing - Camshaft & timing - Front cover seal
Front cover seal, celica - sohc 1986
Front crank seal, mr2 - 4 cylinder 1991 - 1994
Engine - Camshaft & timing - Camshaft & timing - Case seal
Case seal, all models - 2.8l, 5m-ge 1984 - 1988
Front crank seal, all models, to 05/85 - diesel 1984 - 1985
Front crank seal, all models, from 05/85 - diesel 1985 - 1986
Front crank seal, camry - gas, 4 cylinder, 1.6l and 2.0l dohc 1987 - 1990
Front cover seal, camry - gas, 4 cylinder, sohc 1984 - 1986
Front cover seal, pick-up - 4 cylinder diesel 1984
Engine - Crankshaft & bearings - Front crank seal
Front crank seal, camry, to 9/96 - 2.2l 1995 - 1997
Front crank seal, camry, from 9/96, w/o solara, usa built, usa made part - 2.2l 1997 - 2001
Front crank seal, camry, from 9/96, w/solara, usa made part - 2.2l 1999 - 2001
Front crank seal, mr2 - 4 cylinder 1995
Front crank seal, rav4 - 1996-2000 1996
Part Number Search Results : Collision Catalog
Item Number MSRP Core Price Price
Engine - Engine parts - Oil seal
Oil seal 1996
Engine - Engine parts - Damper and pulley - Oil seal
Oil seal 1989 - 1992
Part Number Search Results : OEM Catalog
SEAL, TYPE T OIL
MA70Snowman
374
San Diego
AWSOME thanks man, once i had that part number just 2 calls and I had it. I keep forgettinga bout that EPC, and where its located lol. (definatly marked it this time) but preciate all the help guys thankyou much.
