Wheel stud thread pitch
Big Wang Bandit
You Can't Quit Me Baby
Feb 21, 2006
7,551
San Ramon, CA - 925!
I need to know it. I have 3 stripped studs. No need to lecture I jsut need numbers. Im looking to get a die to see if I can safely rethread the studs.
12mm x 1.5 or 12mm x 1.25
Or am i completely off?
inline6
Whistle>Whine
Sep 22, 2005
208
SoCal
Wheel studs are ony a few bux each. Your probly looking at less than 10 dollars to just buy some replacements, unless there is some reason you really want to fix what you have?
Big Wang Bandit
Feb 21, 2006
7,551
There is a reason... But it just leads to another problem replacing them... From what I gather the hub needs to be removed to access the studs. Not that being if i removed the hub isnt there a seal in there that will needs to be replaced? If not I can get some good ones today...
Big Wang Bandit
Feb 21, 2006
7,551
Thanks Jeff. Im gonna rethread em and see if they look okay.
Or if someone can tell me aobut removing the hub.. or how to get the studs out. I can do that today as well.
Big Wang Bandit
Feb 21, 2006
7,551
Okay. I heard it from Figgie. Must be truth ;)
Any way of going about removing just the dust shield to geto to the back of the hub? I should go look but i want something set in stone.
Big Wang Bandit
Feb 21, 2006
7,551
Okay. Now its time to figure out how to go about removing the hub...
Hopefully by the time I get some new rimmmmz (Matt's Awesome black ones) Ill have 5 lugs again.. Time to go to toyota and ask for that seal!
Big Wang Bandit
Feb 21, 2006
7,551
Yes this is for the front hubs... I need to get some new lugs(chriso...) And at LEAST 3 new studs.
And now just cause I think im gonna clean my threads on the lugs... the tap I would purchase would be a 12mm x 1.5?
Is 1.5 what we agreed on?
You'll be able to see if there is a position that lets you knock the stud out the back when you remove a disc Hells, if not it's Hub pullin time!
(been years since I've had a hub off here)
