whatup with the tems dash lights 12?3?
speedfreak
SCruzer
May 16, 2006
109
santa cruz, ca.
my 92 supra turbo only shows my third tems light in the dash sometimes i havent figured out why. one is always on and the second turns on with the sport mode button for my shocks. but sometimes my third tems light comes on, often when the car is hot or im using alot of turbo, i have the four speed auto and the power ect option. anybody know bout that
Mine always lights up when I'm going around a curve or driving fast. I don't know why, but it does. I now have mine disconnected because of my new coilovers.
C
cnewingham
Guest
the third one only comes on sometimes because that is how it works. It is suppose to stiffen up under hard turning but I think it is actually controled by the tps signal. You can do the sogi tems mod if you want it on all the time.
Dirgle
Conjurer of Boost
Pauma Valley, CA
It actually has several inputs. TPS, Steering wheel sensor, brake sensor, and Speedometer. The TEMS Shock will go to full firm(the third light will illuminate) if you do one of several things. Hit the brakes, Corner while the car is moving. Accelerate hard, or go above 37 MPH in sport mode.
jetjock
creepy-ass cracka
9,439
37 mph? Huh, never seen one do that.
TEMS has 3 settings:
1) Soft
2) Medium
3) Firm
It has 2 Modes:
1) Normal
2) Sport
It has 4 functions:
1) Anti-Squat:
Upon abrupt application of the gas pedal the system goes firm. Input signal is the TPS. This is the only function where the TCCS communicates with the TEMS computer. It's also the only function that operates with the engine off. You can use it to test your TPS to some extent.
2) Anti-dive:
Upon application of the brakes the system goes firm. Input signal is the stop light circuit.
3) Anti-roll:
Upon abrupt application of the steering wheel the system goes firm. Input signal is by an optical sensor mounted in the steering shaft.
4) High Speed:
Around 80 mph when in Sport Mode the system will go firm. Input signal is the vehicle speed sensor in the speedometer.
The system has built in diagnostics by using a jumper in the diag block. See the TSRM for details.
Clip
The Magnificent Seven
Oct 16, 2005
2,738
9
Virginia
mine goes from soft to medium at 65-70 and stays at medium until i get back down to 60. sadly, i don't have the actuators or shocks. some damn shop took them from the last owner.
He answered your question in post 8 here.
Dirgle
Conjurer of Boost
Pauma Valley, CA
Sorry, you're right. I got it backwards. It will go firm if you apply the brakes above 37mph. I remembered hearing 37mph somewhere, and initially though it was for the high speed mode. I haven't had my TEMS connected if a few years so my memory is a little rusty.
MK3.0dudeman
brian L.
Mar 12, 2007
1,628
North Jersey
the second light thats always on shows that it's activated the third one shows that the cars stiffing up like around a turn at a good speed.It's just shows that it's doing what it's spose to.now i don't know why it's only works when it's hot unless you get it hot when your driving it hard:yelrotflm
