what's this thing?
Oct 11, 2005
3,819
21
Thousand Oaks, CA
BY the way, the stock pressure sender is not your typical variable resistance sender, it actually outputs a digital pulse train whose period is proportional to the pressure. Also, it is an input to the TCCS for idle stabilization.... strange but true!
theKnifeArtist
Fire on High!
Apr 6, 2006
2,332
North Jersey
Idealsupra said:
i personally wouldnt if you have the proper threads....however it wouldnt hurt anything if you did so.
yeah i'm getting an adapter for the right thread and teflon-ing that.
are you saying i may have idle problems with an aftermarker sender unit?
Idealsupra
Orlando
www.tampabaysupras.com
starscream5000
Senior VIP Member
Aug 23, 2006
6,359
Hot and Humid, KY
Idealsupra said:
Slight bump from the past here, but since this post was referenced today I'd like to add that the second link is a damn nice piece to have! It's a snap to install the oil pressure sender in one hole, and an oil temp sender in the other. Thanks in advance for taking your time in finding that one!
