Whats everyone running for fuel mangement
Koenigturbo
1,336
Oxnard CA
I'm only looking to get 400 h.p. for my ride.
Here's my mods:
57 trim turbo
Lexus a.f.m. with 550 injectors
3" exhaust and "Lipp" elbow
"XS" Power" Dual stage boost control
H.K.S. F com preprogrammed R.O.M. 550 chip and G.C.C.
I have to run the stock a.f.m. for smog reason's
I'm looking for a plug and play system.
Whats every running for fuel management?
what made you decide on the fuel mangement you have?
What are your mods??
Was it Easy to use?
Koenigturbo
1,336
Oxnard CA
yes it is vaguely familar,isn't it? The last time I asked,I was asking between Maft pro and H.ks. only because I already have the h.k.s., I read so much about the Maft pro which sounded nice. I'm not sure which way to go, so, this time I'm leaving it an open end question and not favoring any brand.
I just happened to have H.K.S. (The F Con ) with 550 rom chip and a g.c.c
Does that answer your question? Maybe I don't understand what your asking.
MKIIINA said:
http://www.supramania.com/forums/showthread.php?t=42618
hummmm vaguely familiar? you need to tell us what H.K.S. (usually just hks btw...) you are running.... not just "H.K.S. and G.C.C. "
Koenigturbo
1,336
Oxnard CA
Where's the Poll?? can you show me what you mean?? I'm obvoius haven't seen that part of the forum
Newb
"oh I see it now, I'll move it, better yet, would you move it for me???
Reign_Maker said:
Where's the "POLL" newb?
Doward
4,245
Alachua, FL
Running MAFT-Pro in Speed Density, and getting ready to trade it for a TEC-2 setup minus the trigger wheel/pickup and ISC.
Doward
4,245
Alachua, FL
Yep. I'm rewiring my harness anyway, and pulling the motor out. Going to build the trigger for the crank into the ATI damper, and have some fun!
Reign_Maker
Has cheezberger
Aug 31, 2005
5,767
Florida
Newb
I change the title for you...
Anyway, my first turbo Supra was just an SAFC2... I still ran the AFM...
Second turbo Supra, I ran an HKS VPC w/ an SAFC2 wired in to clean the signal... The VPC was incredibly easy to use... I made 512rwhp at 23psi using this management, only ever so lightly touching the SAFC for top end on high boost... I could have easily made more, but my secondary pump was being fueled by the sock pump and it just ran out of steam at 23 pounds of boost...
My new set up has twice the injectors *1000cc*, probably 4 times the fuel pump, and will all be run by AEM... Plus the turbo is ALOT bigger, so I should be able to make a little more power... :)
MKIIINA
Destroyer of Turbos
Plano, TX
ok i am running the HKS VPC and the HKS GCC.
what was confusing and unclear was you just put down H.K.S. no what the specific part was. its like saying I drive a toyota....
