What's better stock or ebay exhust manifold????
aye mate
Hiatus over.
Maryland
Why? All the turbos that bolt to the stock manifold are internally gated. I think you need to research turbochargers more because not many of your questions have really made any sense. IMO.
pearlwhite turbo
booost'nnnnnn
Oct 8, 2006
55
philadelphia
Well The turbo That I'm Using T04b garret, does not have an internal wastegate, Someone mentioned that the T04e bolted right on to there stock manifold, but never metioned if theres had and internal wastegate or not. I'm just trying to gather information for my build and now the direction to head in.
aye mate
Hiatus over.
Maryland
If your turbo is a Garret T04b then it will not bolt up to the stock exhaust manifold because it has the wrong flange. I am assuming that is a T4 turbo and you will need to buy either an adapter or a full out T4 manifold.
mazzer
438
st.louis,mo
mine is internally gated
YoNkErS87t
streetside mechanic
In the Garage
pearlwhite turbo said:
Well The turbo That I'm Using T04b garret, does not have an internal wastegate.
you will need a aftermarket manifold and a external wastegate to work with your turbo wether it fits up to stock or not.
supramike7m
92 teal-wn turbo
Jan 29, 2006
759
prescott, Arizona
aye mate said:
Does yours bolt to the stock manifold?
yea mate, those turbonectics do bolt on the were made for our cars, they use the same type of housings, so you can bolt to your manifold, and downpipe. most to4 will not though.
pearl white, you really need to do some research on turbos man, i agree with aye mate, your questions dont make sense. if you have a to4 turbo you need a adapter or t4 manifold. unless its a bolt on deal like the jt, boss, or turbonectics bolt on. if you dont have a internal wg. its not bolt on, get an adapter or a manifold, external wg, lines, and custom Down pipe.
pearlwhite turbo
booost'nnnnnn
Oct 8, 2006
55
philadelphia
I agree, Some one had mentioned that theres match up to there stocker manifold, I have not even attempted to match them up, I just thought mines might fit, Sorry guy's I'm still a noob to the supra scene. You guy's will like what you'll see in the next month or so.
