What will I need for a 1JZ swap?
gregorybeery
Santa Rosa
I have a 1988 Toyota Supra N/A and I am buying a 1JZ from a jdm website and it comes with all this:
1JZ Engine block Top and Bottom
RWD 5 Speed Transmission with ECU
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TWIN TURBOS
FUEL RAIL
THROTTLE BODY
SPARKPLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECCTORS
SPARKPLUGS
OIL PAN
VALVE COVER
MASS AIRFLOW SENSOR
IGNITER
UN-CUT WIRE HARNESSES
ECU
ACCESSORIES (STOCK MOUNTS & SENSORS)
What else will I need to purchase?
Thank you
JonoTurbo
Going for broke
CT
Since you have a pre-89 car you will also need custom mounts such as the ones sold at bicperformance.com.
You will also need a driveshaft for the r154.
Assuming this is a supra 1jz, you will also need either the rest of the hydrofan system, the parts to convert to a clutch fan, or an e-fan.
If you want your oil pressure gauge to work, you will need the adapter from driftmotion.
You will need a 91-94 maxima power steering pressure line to make the power steering work.
You will need a throttle cable from a 92-96 Camry or Corolla.
Along with a few other things which i'm sure I forgot. If your current car is auto, you will also need all the 5spd swap parts.
