I have a 1988 Toyota Supra N/A and I am buying a 1JZ from a jdm website and it comes with all this:
1JZ Engine block Top and Bottom
RWD 5 Speed Transmission with ECU
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TWIN TURBOS
FUEL RAIL
THROTTLE BODY
SPARKPLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECCTORS
SPARKPLUGS
OIL PAN
VALVE COVER
MASS AIRFLOW SENSOR
IGNITER
UN-CUT WIRE HARNESSES
ECU
ACCESSORIES (STOCK MOUNTS & SENSORS)
What else will I need to purchase?
Thank you
CLUTCH AND FLYWHEEL
PRESSURE PLATE
INTAKE MANIFOLD
EXHAUST MANIFOLD
TWIN TURBOS
FUEL RAIL
THROTTLE BODY
SPARKPLUGS
ALTERNATOR
STARTER
AC COMPRESSOR
POWER STEERING
INJECCTORS
SPARKPLUGS
OIL PAN
VALVE COVER
MASS AIRFLOW SENSOR
IGNITER
ECU
Thank you
