what type of igntion system do you run
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
well right now i plan on runing a nogly hot wires
but i was thinking of run a tiwn power or a msd unit
what do you guys think
and what do you guys run
bluemax
The Family Man
Orange County, CA
supraman7mgte,
I like your motor set-up. Everything is so neat and clean just like factory. How do you get past smog with the hard pipes and the bov?
thedave925
Since 9/16/05
Nov 9, 2005
626
East Bay, Cali
IJ. said:
MSD = bleh x 10
i see that you've got an opinion. but could you give some real-world examples/reasons why you don't approve? Supraman atleast admits that it was unnoticable in performance, but i'm more interested in mpg info, especially when the maft-pro is added to the mix.
-dave
Edit: apology for thread jack, i would also like to upgrade my ignition if its worth it
NashMan
Aug 5, 2005
4,940
17
Victoria BC
-dave
hummmm well this is to funny no one here has ever bother to play wiht the stock igntion system
-dave
Dave: I was running 2 x Dis-4 CDI's with MSD CDI Coils.
I had one box fail within 4000 KM's but suspect it may have contributed to an engine meltdown on the dyno.
Nash: The stock system if in good condition should be fine for most 7M users,
"good condition" is the operative term here most aren't.
chevyeater
wastegate hose is pulled
Long Island, NY
NashMan said:
so has any one els run tiwn power on turbo car or msd with stock computer
Yeah, the HKS DLI is reliable and definitely helps out. It isn't as powerful as some of the twin cap CDI systems though like Autronic, M&W and AEM (the AEM is soon to be available again, hopefully more reliable this time). BTW, you will not see much, if any gain from an ignition upgrade unless you are blowing out spark and losing power currently.
NashMan
Aug 5, 2005
4,940
17
Victoria BC
well yes i don't have spark blow out but more powe full spark is more efitiant
akak burn all the gas
teh stock igtion for the supra is great but it the only stock thing left so it must be upgraded hehehe
as for going msd humm may be more money then i wana spend it was pretty much just a qestion asking if any one has done it befor
but the hks tiwn power is on my mind mixed with nogly wirei think it can't be beat
supraman7mgte
Shut up,bitch!!
Sunny California
bluemax said:
supraman7mgte,
i was looking into that the other day,i added all that crap afte rsmog. thnk 'm boned whe i go to test!!!
X-man
member
Dec 5, 2005
309
Pulaski,Va
I had to upgrade the ignition on mine when I started blowing the spark out at 29 psi on my SP67. I tried colder plugs and new wires, plus different coil packs and even an ignitor just to make sure I had a good ignition system. I run NGK wires on the car and have no problems at all with them. I went with the HKS DLI. I noticed a difference with off boost responsiveness on my car as well as not blowing plugs out anymore under boost. HTH
NashMan
Aug 5, 2005
4,940
17
Victoria BC
IJ. said:
Nash: If you want a MSD Dis-4 + racing CDI Coils I can do you a killer deal on my working unit and 6 coils!
hummmmmmm tempting how much we talking about take her to pm and we can mabye work out deal
NashMan
Aug 5, 2005
4,940
17
Victoria BC
this is one thing i wanted to here
besides the blow out thing caus ei don't thinki will push 29 psi cause i am a panzy i thinking 18 psi for now but we will see
oh yae x man do u run a stand alone of some sort
joliroger4
Flying Dutchman Pilot
Apr 4, 2005
264
New Jersey
www.geocities.com
I know it is too late now, but I am running DIS-4s on my supra and truck. Getting them to work properly was difficult, I had many issues, but after a month I got them sorted out. The culprit was the stock coils could not handle the voltage output of the MSD. They were arcing off everything under the hood! I had a good ground and I tried 3 different coil packs, one very low mileage which held 26psi just fine. Difficult to see the arcing unless you like standing outside your car in pitch black with your hood open and car running. So my parts list was the DIS-4 $400, two tach adapters $100, and 3 MSD GM style coils $120, GM terminal ends to install on my NGK wires $10. Its actually really simple to install once you know what's up and the MSD coils are better than the stock one's and cheaper than new Toyota coils.
I would have went the DLI route for price, but I needed the 2-step and timing functions of the MSD for what I do. My whole reasoning in getting the MSD was for those features, spark benefits were icing on the cake in my case. Both units work great so far, haven't been to the track with them yet though. Soon as the weather warms up! :)
Install pics:
http://www2.davidconsentino.com:8000/Supra/DIS-4 Install/
