What turbo would fit my needs best?
Status
Not open for further replies.
AbsoluteSpeed
735
Edmonton AB
Motor:
Built 7M .020over
C/R 8.8:1
I want to run 15psi daily but have the ability to run up to 21psi
on a fairly efficient turbo that still spools around 4000rpm
What would you recommend and how much power do you think it would ultimately put out?
AbsoluteSpeed
735
Edmonton AB
When I had the motor built the mechanic said it would hold up to 21psi.
I was trying to figure out where that would put me power wise and what turbo would best get it there.
So no budget, the use would be less street driven and more track.
AbsoluteSpeed;1403932 said:
When I had the motor built the mechanic said it should be able to hold up to 21psi.
^ None of that answers my questions.... :nono:
21psi is very different on a GT30 and a GT45.
I ask 3 questions, you fail to answer and mumble some crap about 21psi, I ask again you answer 1 question....
this is done don't post it again, go try SF you'll get all the answers there.
Status
