What size vacuum lines are on this thing?
NCSupraowner
100
NC
I've searched for a listing of vacuum line sizes and I'm coming up dry. I'm sorry if this is already up, but can someone tell me what size the vacuum lines are 1/8", 1/4", etc? I want to replace ALL of them at once.
To be honest, get the hose from the dealer. Hell, they GAVE me the hose and didn't charge me anything and it fits the way it should unlike the parts store stuff...
WhtMa71
D0 W3RK
Apr 24, 2007
1,813
Macon, GA
I needed about two feet vac hose and a local parts store just gave it to me.
If im looking for a certain sized hose, I just bring in a piece of the old hose and match it up and guess how much i need.
The problem is that standard size hose isn't the same size at the metric hose that's on the car. It's close, but not the samem so you have to ziptie everything instead of just put it on...
92nsx
2,957
Clearwater, MN
1/8" hose will fit but it will be loose. Try and source 3mm vac. line.
3mm=.118"
1/8"=.125"
Might not look look like much but put some good boost on them and you will see what happens.;) You can also put a "zip-tie" around the end of the hose so it wont "pop" off but that dosen't look to nice.
