What size tires should I put on saws?
8,900
The only way to measure any rim before balancing a wheel.
The sawblade is the one of only a few that is that much bigger than stamped, in my experience.
edit: But you still should not go bigger than 225 on that rim. Too big of a tire on a rim will make the contact patch smaller.
Jeff Lange
Administrator
4,927
Sunnyvale, CA
jefflange.ca
What I was asking is if you measured it inside lip to inside lip, or outside lip to outside lip. I'm assuming you measured inside lip to inside lip, right? If so, maybe it is 7.5", but I doubt it, since I've never seen Toyota not just say the actual size before.
