IJ.;1472707 said:Full mod list would help as 18psi on a ct26 is very different to 18psi on a gt45.
IJ.;1472807 said:I'd try NGK #7 Coppers @ 30 thou to start then see if it blows the spark out around Tq peak (5200 rpm) and drop the gap if needed.
suprahero;1472815 said:When I first read it I thought he was saying he had a .060 mm head gasket, then I was like, no way. I figured it had to be bored .060, but I didn't know if that was possible or not. My 2jz is bored .040 but I wouldn't go bigger than that.
xms;1472820 said:NO NO my block is 20 over and the .060 is the thickness of my gasket from cometic the thickest one they offered
IJ.;1472823 said:Cometic do a 3mm MHG, if it's .06" that's 1.5mm?
