What is this sound?
Master_Spazez
60
SC
Now I've had rod knock before, and this doesn't sound like it! I've listened to the block (2 different places), head, and exhaust manifold with an extension and the noise is loudest from the head. The oil pressure rises and falls normally, and isn't any harder to start than normal. I thought it was a lifter, but then I remembered it just uses lash pads! Any ideas?
http://www.facebook.com/photo.php?v=2960232299161
MPR
John 3:16
Dec 17, 2011
221
Toronto, Ontario
That is definitely NOT an exhaust manifold leak. When the camera is near the back of the block above the head you can clearly hear metal on metal ticking. It's gotta be something in the top end/ valve train...
Pull the Cam covers and check the valve clearences with feeler gauges when each cam lobe has it's back to the bucket, for it to be this noisy it should be apparent.
Lighter oil could be a factor but check the basics first (lighter oil will displace easier so it "might" be rod knock but I'd run the buckets first before hitting the panic button)
This is why I asked you to run it up and hold it around 2500 to see if the noise changes.
Master_Spazez;1798663 said:
When I held it around 2500 the noise got quieter, completely nonexistent at idle. I'll be checking clearances today.
Ok NOT a good sign sadly :(
Run the engine and pull 1 injector clip at a time then replace it and move to the next, post back here what happens noise wise.
Master_Spazez
60
SC
Why what is that a sign of? When I pulled spark plug wires the noise got equally quiet for each one. I checked clearances today stone cold and they were all within spec. It just seems too rattly/tinny/rhythmic to be knock because when it was knocking last time it was a deep "KNOCK" and it didn't have a pattern to it.
Also I didn't hold it at 2500, I just revved it up a few times (don't know to what rpm) and the noise got quieter.
If you're not going to try what I suggest I can't help you... :nono:
Master_Spazez
60
SC
I will but I drained all the oil out of it so I wont be starting it until Monday, I didn't get to NAPA in time to grab a filter.
AJ'S 88NA
2,419
Florida
I've spun a rod bearing 3 times now and it sounded different each time.
What's your oil pressure doing, each time for me it dropped quite a bit.
Master_Spazez
60
SC
As I've said its still normal oil pressure. I won't be able to run it again until Monday, I didn't get to NAPA in time to get the oil filter. -_-
Master_Spazez
60
SC
I've pulled each injector plug like IJ. said to and the noise does not drop at all, aside from becoming quieter from the RPM drop. However I put my hand around where the exhaust manifold and the downpipe meet and I can feel the exhaust coming out there, which may explain why it is so loud. I guess my punishment for not having a proper header, haha.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
Ding, ding, ding. Winner.
I've always been surprised how much an exhaust can sound like physical metal on metal contact. Actually feeling the exhaust leak is about as much proof as you can get.
MPR
John 3:16
Dec 17, 2011
221
Toronto, Ontario
I've never heard a manifold leak sound like that in my life. (and I've heard many). If it turns out to be a manifold leak, I stand corrected and very surprised. :)
