What is this plug??
peteremer
26
virginia
Hey everybody, I am helping my friend put his 7mgte back together after a engine rebuild, and there is a plug coming out of his wiring harness on the turbo side of the engine that doesnt seem like it has anywhere to go and there isnt one on either of the supra's i own. Any ideas?
Thankya
Pete
Just a guess, but it looks like the size of a Cold Start Injector Timer. I'm guessing as I see other Thermostat housing connectors missing in the picture.
There is also some A/C related connections on the lower fender wall, but I can't remember what the connectors look like.
peteremer
26
virginia
It does, as seen in the picture..I was looking at another 91 wiring harness an it had the plug on it as well...unfortunatly it wasnt on the car..this plug wasnt on my friends 87 or 89 supra?
NewGen
799
Norwalk, IA
Anyone have an extra one of those plugs they wanna cut off and send to me :) My powersteering belt exploded and caught mine and riped it clean off. If you do just pm me.
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
I have that same plug disconnected and I have no idea where it goes. I started a thread on the main forums a while ago and no one had an answer.
http://www.supramania.com/forums/showthread.php?t=60759
Buddafucco
Beef Supreme
Mar 3, 2007
214
Tampa Bay
It looks like the thermo time switch from a newer motor (what thelonerider said) . Both pictures are shifted to the left just enough so that we can't see it.
peteremer
26
virginia
Yeah the same for me, all of the other connectors are hooked up..I wondered because it had the heat wraping around it if it went somewhere around the turbo but there are simply just no places I see to plug it in after 3 days of looking....? Did you start your car without it ILikeCars?
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
Yeah my Supra runs absolutely fine without it. I'm just somewhat anal and don't like the idea that the plug is disconnected. Some suggested power steering, some suggested an oil level sender.
The Supra will be fine without it.
ILikeCarsYesIDo
Permanently Banned
Nov 26, 2007
416
Hayward, CA
Nope, I have the original factory harness. I thought it was connected to my other engine but for the life of me I couldn't figure out where. I looked up and down my old block and I didn't see any place for it to go. All of those mentioned places are connected.
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
Hmmm. Maybe someone just put it there to fuck with you:dunno:
Have you tried checking continuity with the ECU connector?
Quin
Trans killer
Dec 5, 2006
1,989
Columbus, IN
It bugs me now. It's too cold to see if I have it, I might check later. Peter, you do it, you live in a place far less cold lol
peteremer
26
virginia
alright, later tonight I am going to check the continuity and figure out where it ends up in the wiring harness-plugging into the ecu and that should help me figure out where it's going. I'll keep you all posted.
